PIR Sensor Burn Out | Page 2 | on ElectriciansForums
Discuss PIR Sensor Burn Out in the UK Electrical Forum area at ElectriciansForums.net
B
benfreke
Hello,
Can placing a piece of cardboard over a PIR sensor for a light cause it to burn out? I have been told that the cause of the sensor failing is the piece of card that we placed over it for a while to stop it being turned on; but I simply cannot imagine that an infrared sensor would burn out because of a piece of card?
Could someone help me with this?
Ben
Like has been said - no!
you have been strung a rope and it pulled u in!
why are you using cardboard to stop it activating? If it's to isolate (keep dead) this is very bad practise as some clown may remove said cardboard.
Isolate MCB or remove load live from PIR for your safety!
only thing - check max current/power as overloading will cause it to burn out. been there got the T-Shirt with a photocell. 6A through a 5A photocell
just increase the voltage to 290v and the currentz will go down...... :81:
Reply to PIR Sensor Burn Out in the UK Electrical Forum area at ElectriciansForums.net
In the mind of someone lying there wide awake at 3AM, just about anything.
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
