PIR sensor light installation help | Page 2 | on ElectriciansForums
Discuss PIR sensor light installation help in the Lighting Forum area at ElectriciansForums.net
it's a class II fitting. does not need earthing. see terminal block bottom corner of instriuctions. brown to brown(L), blue to blue (N). park earth wire in centre terminal.
I mean i would put the earth wire next to blue and brown? So it would be 3 in a row for the wires on the same terminal. Or would i put it on the other side of the terminal in the places i'd put the blue/brown.
Managed to put it up this afternoon. It came on for about 20 seconds or something, then it clicked on and off a few times then it went off. Even waving in front of the sensor didn't make it come back on again, but i am not sure whether that is due to it being broad daylight or what. In a few hours i'll find out, because i've wired it up correctly. During the fiddling process of putting the wires in/putting the front of the lamp on a brown wire came out, which i knew was the case but my family member who helped me said it hadn't happened so i took it apart again and the brown wire had come loose (after putting the wire back it stayed on, then clicked 3/4 times on and off then it went off again)?. In just under 3 hours i'll see if it comes on during darkness when i walk past it.
Reply to PIR sensor light installation help in the Lighting Forum area at ElectriciansForums.net
That will work fine as long as the Pirs use relay switching, some don't.
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
