please help lighting problem | on ElectriciansForums
Discuss please help lighting problem in the UK Electrical Forum area at ElectriciansForums.net
demkap
Hi there,
im wondering if anyone can help me. im a qualified electrican but have never come across this problem. basically in a church there 6 flood lights inside on each wall left and right side. the whole right side is not working as it should. one light comes but then the next light seems to come on but not at full brightness, like theres a voltage problem. then when i flick the switch one light goes off and the other comes on but they should be on together. theres 3 switches 2 lights per switch, but its like the whole configuration doesnt work and they dont all come on or stay on....
please help???
yea checked connections weird thing is theres power in all of the flood lights, is there such thing as a voltage problem? i just dont get how they come on but not fully and also not with the correct switches
Are the lighting fittings the original? or have they been replaced by larger ones recently? by larger I mean are they a larger wattage?
they are 400w flood lights so theres 6 and 3 switches but even the configuration seems messaged up, the first one comes on but when the second switch it pressed it goes off and the second comes on but its really dim barely on at all....
Sounds like a duff neutral connection, but I 'm shooting in the dark, what tests have you carried out? connections checked OK?
Reply to please help lighting problem in the UK Electrical Forum area at ElectriciansForums.net
Not to mention welding switch contacts together and wondering why when they thought they had got the wiring sussed the light will still not switch...
Can you get a supply to your new light at all from elsewhere ?
