C
cyberjunction
Hi
I am doing my first consumer unit for my assesment on Friday and have come a cropper.
I have put in a split dual consumer unit, Wylex.
On the one half, closest to the main switch, the rcd works fine.
The second RCD, the test button does not work . When I apply a load ie upstairs kights , it trips straight away.Obviously thought the RCD was faulty so took it back and got it replaced and the same problem. I have disconnected all lines form the MCB and the buzz bar but the same problem. I have ensured there is no connection between the neutrals on the neutral bars as some one suggested and am completely stuck,
Can anyone help, I am panicking with my assesment due and am hoping this is something silly.
Just a note there is voltage to the RCD.
the preivous consumer unit was a single rcd and MCDs with problems
