I never bothered with those website things and I've never been a fan of plastic pipes since I brought a ceiling down soon after the stuff appeared on the market, but to be fair, it wasn't the pipe that failed - it was the fitting, but since then I have only used it as a sort of Get out of Jail Free" card.
"Hello Geordie Spark",
I will NEVER install anything other than Copper pipe for Domestic Heating and Plumbing [water distribution / circulation] - except obviously for Underfloor Heating installations !
Even then I have turned down some Underfloor Heating Jobs - I just don`t like working wth `Plastic pipe` - almost invariably the Underfloor Heating pipe is damaged somewhere / in several places by `Others` on the Job before the Screed is laid.
Even though it would be pressure tested - `Kinks` / or a Flattening of the Pipe is a `Weak point` on a Heating system because the inside surface will have been damaged !
I have done Underfloor Heating where I returned to the Job on the Day before the Screed was to be laid to check my pipework only to find loads of Damage to my Underfloor Heating pipes !
I then could NOT allow the Screed to be laid the next Day because the pipework was ruined - and this has caused plenty of animosity and delays on those Sites - I have had to completely Re-Pipe some of these Undefloor Heating Circuits and then have problems / arguments about getting paid for it !
I admit that I am `prejudiced` against `Plastic Pipe` as I am a long standing Member of the UK Copper Club - within the UK Copper Board who I am sure You know exists to promote the use of the BEST materials for use in Heating - Plumbing and Gas Installations = COPPER.
They also provide most of the Training Information / detailed Installation methods for Plumbing Apprenticeship Training in the U.K.
Obviously I know that Copper cannot be used for Underfloor Heating Circuits because of Jointing and the prohibitive Cost - but that is the ONLY application where I would use `Plastic pipe` - clipped down securely on the Floor Insulation boards and in continuous lengths with obviously no joints.
I have refused to do many Jobs where `Plastic Pipe` was to be used on the Plumbing and Heating - some of those prospective Clients changed their minds about the Installation when I refused to use the Plastic pipe - and because I had been highly recommended to them they took my refusal as a `Review` of the `2nd Class material` and went with Copper pipework - I then carried out the Installations.
As You know Copper pipe installed correctly and which does not suffer from corrosion would last theoretically for Hundreds of Years - despite the specifications and claims for the various `Plastic pipes` the same cannot be claimed for that Material !
I do realise that people will state that NO Heating or Plumbing system would ever remain for `Hundreds of Years` - but as You know I am just stating the longevity of Copper pipe compared to the relatively `unknown lifespan` / degradation of the Plastic pipes and fittings.
Regards,
Chris
