`pond flex` or `arctic` cable for flex connection to outside halogen lights ? | Page 3 | on ElectriciansForums
Discuss `pond flex` or `arctic` cable for flex connection to outside halogen lights ? in the UK Electrical Forum area at ElectriciansForums.net
LONDON
"Hello All",
Please don`t think that this is `too trivial` a question for the Forum:
I have noticed that My Garden / Outside Halogen Lights [500 W] were originally wired with what looks to Me like `ordinary` 1mm Flex.
It looks like the Insulation has been badly degraded by the Weather / UV Light.
I want to rewire these - just about the last 800mm to the Lights - luckily there are Single Gang Surface Boxes with Flex Outlet Plates on the Gable End Wall in the Loft and I would rewire the Lights back to the connections housed in those - the Switches are downstairs - these 3 Halogen Lights / the Lights Circuit has its own circuit breaker on the Consumer Unit.
Here is My question regarding which Flex type cable I can use:
I obviously want to use a `Weather / UV Resistant` Flex / Cable.
IF `Arctic` Cable [3183Y]
is both UV / Weather and Cold Temperature resistant this would be ideal for Me as I can purchase Cut lengths of 1.5mm 3 Core for about ÂŁ1.10 per Metre - I would only need 3 Metres - approx 800mm for each Light including some `slack`.
Before seeing the Arctic Cable I saw `Weather Resistant Rubber Pond Flex` [3183P] - 0.75mm 3 Core - this is described as being `suitable for external lighting - exposed to the Sun`s rays` - BUT this is only available on a 25 Metre Drum at a cost of ÂŁ15.34.
As the `Pond Flex` would only be any good to Me if I have to rewire the last 800mm to these Outside Halogen Lights AGAIN I don`t really want to buy a 25 Metre Drum of it - unless the `Arctic` cable is NOT suitable - ?
As I mentioned - Please don`t view this as too trivial - the Information that I will receive on here will be helpful and possibly save Me aboutÂŁ12.00 [?].
Thanks for your help.
Regards,
Chris - Heating Engineer
"Hello All",
"Hello sparkdog",
Apart from what I wrote the only other `identifying` detail is: 3183Y [1.5mm 3 Core / 15 Amp]
Is that a BS Number ?
I have noticed that the Pond Flex is noted to be 3183P
Thanks for your help - Arctic cable would definitely be much cheaper at approx. ÂŁ3.30 inc. - instead of ÂŁ15.34 inc. for a 25 Metre Drum.
Regards,
Chris
3183Y is standard PVC flex, 3183AG is arctic grade flex somebody somewhere is getting things mixed up beware what of what you are buying
[FONT=&amp][FONT=&amp] BS 7919 [/FONT][FONT=&amp] (3183AG) [/FONT]Arctic flex is only recommended by the manufacturers and BS 5740-3 for temporary outdoor applications e.g. caravan hook-ups, temporary traffic lights and construction site transformers, festoon lights and power tools etc[/FONT].
"Hello UNG",
Thanks very much for your message and for the query about the Spoecification of the Arctic Cable.
As I am not either Advertising or Identifying the Electrical Wholesaler concerned I hope that I am not breaking any Forum Rules by posting the Screenshot from their Catalogue below - this shows the 3183Y `Specification` and the comment about `Outdoor Use`.
Regards,
Chris
BS 7919 (3183AG) Arctic flex is only recommended by the manufacturers and BS 5740-3 for temporary outdoor applications e.g. caravan hook-ups, temporary traffic lights and construction site transformers, festoon lights and power tools etc.
"Hello MarkieSparkie",
Thanks for the Information about the Arctic Cable - UNG has also stated that the Electrical Wholesalers that I was going to use have got the Specification wrong when they state: 3183Y
What would You suggest I use - hopefully without having to buy a 25 Metre Drum of `Pond Flex` - ?
If the `3183Y` Arctic Cable is both incorrectly indicated regarding the Specification - AND even a correctly Specified Arctic Cable is only for `Temporary Connection` Use - I might as well use `Ordinary` Black Flex - as suggested by other Members - ?
Regards,
Chris
Never come across such a polite and diligent poster as this "Chris Murphy".... if that is your real name.
Astounding attention to detail. What a well mannered chap. Absolutely no sarcasm involved.
"Hello wade88",
Thank You for your message and for the Compliment.
I do try to be Polite in every aspect of Life - unless I get a good reason to change My approach.
Regarding My `Name` - would I be correct in thinking that MOST of the Members on the Forum do NOT use their First Name and Surname as their `Forum Name` - ?
Although I have nothing to hide I believe that it is `Normal` to use a `Nom de Plume` on a Forum - ?
Regards,
Chris
Reply to `pond flex` or `arctic` cable for flex connection to outside halogen lights ? in the UK Electrical Forum area at ElectriciansForums.net
