Does anyone else find that more often than not, no consideration seems to be given in wall light fittings for allowing two cables to fit in properly? Been fitting some led bulkhead type fittings and you'd barely get one t&e into the cable entry let alone the 2 x 3core cables required (emg fittings). 'fancy' bathroom wall lights are often even worse, when they come with those tiny terminal block connectors and rubber sleeve bits!! Frustratingly poor design in my opinion. Grumble over.
