pop riveting good or bad? | on ElectriciansForums
  • Thread starter sledgehammer
  • Start date
  • Replies 25
  • Views 4K
Discuss pop riveting good or bad? in the Talk Electrician area at ElectriciansForums.net
S
sledgehammer
Pop riveting metal trunking looks great but what about continuity and fault current capacity?
Like any standard manufactured joint you fit a bonding strap if required for earth continuity like when relying on the trunking as a sole means of earth for a circuit.
Saw it the other day. I've always bolted with continuity links but it did look tidy. I think fault current would possibly blow the rivets and that in time continuity would become a issue. Anyone feel that if they were doing a EICR they'd fail it?
Yet again we hear speculation & conjecture in here...
Does anyone actually read what others gave put...
Do what Darkwood has said...which is to fit a strap across the 2 joining sections.....
Oh, and before anyone starts on about pop rivets being weak....then you just try seperating a pop rivetted joint by hand...
furthermore, pop rivets have no sharp edges inside...
I would have thought that fault current wouldn't really be too much of an issue as it's the trunking itself that would carry, not the rivet? I mean, there's always some overlap.
i dont understand the shock horror response of the method discussed ?
ok , so its not done very often but thats down to nothing more than tradition rather than any particular engineering flaws.
rivet joints are a very neat , secure and unobtrusive means of joining metalwork in my mind and i certainly wouldnt record it in any inspection if it was mechanically sound.
Normally you would only make cuts in 2 sides and bend 3rd so keeping 33% of trunking intact, fit straps if deemed necessary or in spec to do so. Some of the best trunking I have seen was pop riveted.
Nothing against pop rivets in the construction of trunking or tray work providing they are of a decent size and fitted correctly. Think i'd be using nut and bolts on traywork that was carrying hefty weights of SWA cables and the like though!! Like so many other things, it comes down to using a bit of commonsense at the end of the day!!
Reply to pop riveting good or bad? in the Talk Electrician area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
Update I’ve been in contact with Solax directly, showed them all the readings I’ve got, and they agree it’s a very high voltage, and that’s...
Good question now to start with thermosetting insulated conductors are not tri-rated that is something different. Table 4E1A deals with this type...
