Potential difference between Earth and Neutral | Page 2 | on ElectriciansForums
Discuss Potential difference between Earth and Neutral in the DIY Electrical Advice area at ElectriciansForums.net
People are free to use as many forums as they wish, All I would say is it's a bit like the first rule of the Fight Club.
Everybody knows the first rule of the fight club Right!!!!
Is that necessary? I don't think anyone would be interested? Is it frowned upon to use two forums? If so why do you use more than on forum? Which forum do you like the best? Why are you making an issue with me using two forums?
I think you're a bit of a pillock truth be told. No wonder you've already served a ban here, every post you've made has an air of arrogance about it. Go use the other forum, you serve no purpose here other than to annoy and irritate.
You could at least pop back and thank mykey for suggesting the answer to your problem. See post #2.
Isn't this the chasing across ceilings fellow again, I thought he was off in the cooler for a while, is he back.
Yeah mate he served his time so play nice:D
Reply to Potential difference between Earth and Neutral in the DIY Electrical Advice area at ElectriciansForums.net
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
2 3
