OK I MOVED TO A NEW HOME, AND EVEN THO THE BILL DOESN'T SEEM TO BE MUCH, COMPARED TO OTHERS AROUND ME MINE IS 6 TIMES AS HIGH. I DID FIND A GROUND SHORT IN A OUTSIDE LIGHT WHERE THE POWER WAS SHOOTING INTO THE GROUND CUT THAT LOOSE AND BILL WENT DOWN ABOUT 60.00. OVERALL MY BILL RUNS AROUND 400 U.S. PER MONTH. I have a 4 bedroom home, but only two people live here. I cook with gas, no heater system, one 12k BTU a/c. two fridges, lights, microwave, hot water tank, ceiling fans, washer and dryer. so what can I do to find out if I have another grounding problem? I have cut loose everything outside, I have changed the main power box, had the power company come out and run new wires, and my home still is far more then others the same size. no one is hooked into my power that I can find. thanks for any help.
