For the illustration you posted supplementary bonding would suffice. The drawings replicates how a kitchen sink was traditionally bonded to the socket where the electric kettle was plugged inIt an extraneous & needs bonding with the appropriate sized conductor
Just wondering how you would connect the bondingFor the illustration you posted supplementary bonding would suffice. The drawings replicates how a kitchen sink was traditionally bonded to the socket where the electric kettle was plugged in
As the OP describes the installation, there are no extraneous parts except for the metal frame. Makes bonding very simple. The metal frame will provide a path to earth but it will likely be relatively high resistance (should be tested and established). A bonding conductor of 4mm from the socket to the metal frame will be more than adequate.Just wondering how you would connect the bonding
Maybe it's not a good idea to export the PME to the metal frame ?As the OP describes the installation, there are no extraneous parts except for the metal frame. Makes bonding very simple. The metal frame will provide a path to earth but it will likely be relatively high resistance (should be tested and established). A bonding conductor of 4mm from the socket to the metal frame will be more than adequate.
Agreed, TT is the way to go.It is really about the relative risks of each of the options:
In this situation I would probablygo with TT due to the 2*1.5mm CPC of the suppling RFC and what that could mean for open-PEN faults. Though I would be tempted to put a RCD style socket as TT on the existing socket's supply so no single RCD failure for anyone plugging stuff in.
- TT avoids the whole open-PEN fault issues of high touch potential and possibly high sustained currents in the CPC irrespective of RCD/MCB protection. But in turn you are dependent on the electronics and light-current trip mechanism to disconnect on any fault.
- TN gives you the reliable high fault current option to disconnect on the OCPD side of things, but in turn you have the issue of differences in CPC/Earth potential leading to the issue of bonding of extraneous parts, etc, open-PEN magintude of currents, etc.
That is one aspect that never seems to be covered as "extraneous conductive" could range from sub-ohm with seriously high open-PEN currents being possible (e.g. metallic service pipes shared with other DNO circuits) to the kOhm range when any mechanically sound bond wire will do.As the OP describes the installation, there are no extraneous parts except for the metal frame. Makes bonding very simple. The metal frame will provide a path to earth but it will likely be relatively high resistance (should be tested and established). A bonding conductor of 4mm from the socket to the metal frame will be more than adequate.
Completely agree. In the domestic sector "bonding" and "10mm" have become synomimous. Interchangeable. Causing unfortunately a lot of confusion and unnecessary expense in the process.I guess the old 10mm, etc, rule is about assuming the worst (but still realistic) case.
Agree TT is the way, it’s been a epic post with many points of view.Agreed, TT is the way to go.
So are the existing sockets not on RCD at all?Agree TT is the way, it’s been a epic post with many points of view.
This just proves that adding a power point to the greenhouse needs a lot of thinking & cost wise, gonna be expensive.
The client literally told us how to connect the power, from an existing external socket.
Shes in for a surprise when priced for TT system, Rcd DB, etc
