Power to garrage | Page 2 | on ElectriciansForums
Discuss Power to garrage in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
because you are coming off a 2.5mm ring. however, if you have a spare way in the CU, you could fit a 32A MCB and feed to garage with 6mm to allow for future increase in load.
Reply to Power to garrage in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Have you checked the RJ 45 type lead that connects the pcb to the power supply in behind is properly connected? What voltages do you get at the...
I'm bad. I forgot that I made this post and I started another that is very closely related. In it I have drawn out a detailed wiring diagram...
