M
mattcos1972
Just a quick question for my own curiosity chaps.
Is there anything wrong with running the power on a lighting circuit to the switch rather than to the rose?
I am asking because normally I would run the power to the rose and then run a t&e to the switch (brown sleeving the neutral before you pass comment ) to create the switched line to power the luminaire(s).
But I have just run in a new lighting circuit in my flat to provide lighting to a new walk in store cupboard and also an up-lighter in the hallway (other side of same wall) and because the main power is coming from beneath the floor boards as opposed to up above the ceiling, and both lights are wall mounted, it just seemed a whole lot simpler (and used a whole lot less cable) to bring the power up to the switch connect up all neutrals and all earths with choc blocks in the back box, (not to each other!! Well I have to be so careful what I say with you lot ) , and switch the lines through the switches (I used a double switch as opposed to one switch for each light). Then I just ran t&e up to each luminaire with the lines already switched (no need for sleeving either yay!)
Later on I will be extending the hall lighting circuit to incorporate more wall lights on the existing switch and I will most likely run a 2 way switch in also. For that reason also it just suits better to have the main power at the switch.
There's nothing wrong with that set up, is there?
