Hi, I'm after some more pricing help if you can, for labour costs from businesses signing off their own domestic work. I'm in the midlands. Assuming RCD and bonding etc is ok, carpet and floor access is fine, chased in, average cable length, and you can crack on, test and certificate if applicable. Thanks a lot in advance if anyone does this (copy and paste). LABOUR ONLY.
Part of UK:
+ VAT or no:
Replacing (like for like) ---
Replacing 4x socket fronts: £
Replacing 4x light switch fronts: £
Replacing 4x ceiling lights: £
Replacing 4x wall lights: £
Replacing 4x downlights: £
Replacing 1x floodlight: £
Replacing 1x 100mm fan: £
Replacing 4x smokes: £
Replacing 1x shower: £
Replacing 1x cooker hood: £
Replacing 1x oven or hob: £
Replacing 6-circuit consumer unit: £
Replacing 10-circuit consumer unit: £
Adding (to existing circuit) ---
Adding 1x socket in a room, cable: £
Adding 3x sockets in a room, cable: £
Adding 6x downlights, cable: £
Adding 1x PIR floodlight, FCU or switch, cable: £
Adding 1x 100mm fan core drilled, isolator, cable: £
Adding 1x cooker hood, core drilled, FCU, cable: £
Installing (new circuit) ---
Installing 4x smokes, cable, OCPD: £
Installing 1x shower, cable, isolator, OCPD: £
Installing 1x oven, cooker switch, cable, OCPD: £
Installing 6x sockets for kitchen, cable, OCPD: £
Installing 1x 10m SWA clipped, garage CU, 2x battens, 2 sockets, OCPD: £
Part of UK:
+ VAT or no:
These are things that you will have to figure out for your self.
estimate how many hours it will take you and quote it using your standard rate.
it depends on the following (not exhaustive list)
if you are working alone or with a mate
can you park on site
can you safely leave tools and equipment on site overnight
type of wall / ceilings you may have to cut / chase
space / access to working areas
difficulty of cable routing
quantity and quality of Tea and biscuits offered
and for some of the younger sparks, quotation amounts are inversely proportional to the length of skirt worn by the lady of the house. ;) ;) ;)
We wouldn't recommend people do this, especially in the public forums. But we have the Electricians Arms which is out of public view where you can discuss pricing but I doubt you'd get responses quite so detailed. It'd be more job pricing guidance etc
Only you know your business costs.
Although it might appear that I am being elusive with the facts,
the point is, only you know what your worth is per hour and how long it will take you to complete these tasks.
I found when i was first starting out that i was under quoting most jobs and it was only by documenting how long it actually took compared to what i had estimated that i realised i had to add 30% to most of my estimates.
Midlands
Pricing jobs
jimidevo,
James,
