Pricing Kitchen rewire and consumer unit upgrade with bonding and Cert | Page 2 | on ElectriciansForums
Discuss Pricing Kitchen rewire and consumer unit upgrade with bonding and Cert in the The Welcome Forum area at ElectriciansForums.net
Out of interest if you are out of your apprenticeship ........... why aren't you a member of a CPS ?
Do you have PL ins?
I am going to put aside my suspicions on the name of Red Kipper sounds like a variant of Red Herring. Your price for testing is way out. First if you are going to change a C.U. then you would ideally do an EICR I charge ÂŁ25 per circuit so that would be around ÂŁ150 (at six circuits?) Seems to me that an eight way C.U. is a bit tight might have gone for a ten way for future needs. Then there may be remedial work such as the bonding you mentioned and maybe other on top say ÂŁ200?? After you have completed the work and during the design and erection I would have to inspect what was going on and test as you go with a set of dead tests before commissioning the C.U. say another ÂŁ100?? so straight away you are looking at ÂŁ450. The materials around ÂŁ200. Then the labour for the work ÂŁ1100 so that's ÂŁ1600 ish. Only STROMA allow third party sign offs so hopefully your mate is with STROMA. I am surprised if you have done your apprenticeship that you are not already able to sign off your own work with testing and commissioning experience hence I was thinking about your name RedKipper being some variant on a Red Herring:)o_O If you can sign off your work then use it to register with a scheme. You have thirty days to test and issue a cert so plenty of time to arrange an assessment for the work.
Hi - I see it's your first post, so welcome. But if you are doing it for a mate, don't you work it out between you? If you are doing it for business then after 3 years of working with an Electrician you should have plenty of experience with pricing?
Never charged for an EICR prior to doing a CU change. Tested the install prior to ripping the old CU out, but never done an EICR for reasonably priced domestic CU change.
Really ?
I have ............ seen a few awful sites where I've refused to give an CU change quote unless I'm allowed to do an EICR first ............
After the last one like this I told them not to bother with a new fuseboard and go for a rewire ............
Really ?
I have ............ seen a few awful sites where I've refused to give an CU change quote unless I'm allowed to do an EICR first .........…
Yep. Granted there have been a few I wouldn't/hadn't touched with a barge pole, but tell me for a standard 3 bed semi, you'll have charged ÂŁ250ish for an EICR first, then ÂŁ400ish for the CU change next? I should of moved down to Woking :)
Who said anything about charging ÂŁ250 ?
I always visit before quoting ...........so hard to tell
It was easy for me. If the job 'looked dodgy', I'd decline. If it was a straight forward vanilla flavoured job, I'd test before the day of removing CU, as part of my quotation for CU replacement. Any faults would be extra's.
So I've never charged for an EICR before a CU change.
Inspected & tested by registered 3rd party electrician, installation carried out by another.
Not sure if it’s practice in Wales. Only two of the schemes are registered, Napit being one of them. Specific procedure to be followed, apparently.
Reply to Pricing Kitchen rewire and consumer unit upgrade with bonding and Cert in the The Welcome Forum area at ElectriciansForums.net
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
What is the distance from the point outside the house to the shed?
