Problem...too much electricity! | Page 2 | on ElectriciansForums
Discuss Problem...too much electricity! in the DIY Electrical Advice area at ElectriciansForums.net
Floating neutral? Isn't that to do with the Swiss navy?
Have disembowelled the LED thing so I now have a spare screwdriver...and some mercury cells!
Here comes Plan B...
1: Go to Scroofix.
2: Get 1x double switch and 1x single one.
3: Switch off consumer unit.
4: Fit switches, wiring like for like, seeking any strays.
5: Fire up and see.
6: Rejoice in the knowledge that the bits with moving parts are new.
7: Wait for sparky chum to arrive to do planned inspection for holiday accommodation safety.
By the way, the dimmer switch is earthed.
No other changes save for putting 12v LED GU10s in kitchen a while ago.
Talk me down, tower...
1: Go to Scroofix.
5: Fire up and see.
when it still don't work, bale out.
Will do, Skipper.
It's actually two 2-gang switches so plan B will cost about Ā£6...plus the skin grafts.
and the new underpants. :(
1: Go to Scroofix.
5: Fire up and see.
Why you may be completely wasting your money on something that is not broke the problem needs to be found first.
I'll see your TX200 with the .22 LR Anschutz Supermatch I shoot at the club and I'll raise you the BSA Martini International MK II on which I have a deposit, (FAC-dependent).
well if we're getting serious, my WW1 lee enfield .303 beats any .22. :)
Well done Doody, I didn't know how far that was going and with that many 'trumps' I tend to exit the room!
I just got a new shotgun at the weekend - my gun safe is now full, so I guess I'd better get another for when my FAC comes through
'Well if we're getting serious, my WW1 lee enfield .303 beats any .22.
One of my archery club compadres has a short magazine Lee Enfield and a Dublin Castle Brown Bess musket. Bessie's flintlock still sparks but both this and the SMLE are decativated - not sure wallpieces count.
A fellow rifle club member has a Sharps rifle that was made in 1872 (from the serial number). It takes 45 cal cartridges(he rolls his own), 125 grains of black powder = 1,000 yards' range - it's a downspout with a trigger.
Back on topic, I got two switches so I can play tomorrow. Watch this space. I don't feel it's Ā£6-odd wasted - the original switches are pushing 3 decades old.
OK folks, it's update time.
Some of you can go into smug mode now. I changed the upstairs switch (actually a 2 gang) and little has changed. A neon shows power at one pin in the bulbholder but the bulb remains unlit. Here's the original switch...
[ElectriciansForums.net] Problem...too much electricity!
As far as I can tell by feel, the bundle of earth-coloured insulting tape contains a chochblock. There appear to be two cables going into the switchbox.
Here's another weirdness.
This is my brand new, shiny 2-gang switch but that common connector (bot right)
is screwed in as far as possible. Screwing it up tight takes only 1.5 turns from fully unscrewed and there's no way it'll grip a wire core. The second switch is exactly the same and the L1 and L2 connectors work fine. It's an MK item and the two will be going back.
In practice, I had to poke the red wire (bent to suit) into the connector hole. Result as above.
Meanwhile, I've called Charles the Sparky and asked him to arrive equipped.
It's all rather odd and it isn't rocket surgery, is it?
Reply to Problem...too much electricity! in the DIY Electrical Advice area at ElectriciansForums.net
Question 1 do you prefer buttered, salted or sweet salted? I'm guessing salty šŸ˜œ 1. Auto range multimeter (used on mains before when testing the...
