Problem with a timer fan on light circuit | Page 2 | on ElectriciansForums
Discuss Problem with a timer fan on light circuit in the Lighting Forum area at ElectriciansForums.net
Maybe the PL and SL are reversed..............
Ive disconnected the SL and with the light switch off if I touch it to the SL terminal and then remove it the fan runs for set time as its supposed to. It is something to do with the voltage constantly in the SL thats still sending a signal?
I'm not following, sorry. This seems to say your manual SL makes the fan work normally, but put SL on a light switch (that's connected to the same circuit) and it's playing up? If so, isn't it the switch? Hasn't got leakage current from a neon perhaps? Or a dimmer ?
If I diconnect the SL once the fan has activated it runs and stops as normal once the time has elapsed. Which leads me to thinking because theres a constant voltage in the SL ( although only low) it dosnt think youve switched off.
You could put a small load on the SL and see if it fixes it? Pilot lamp perhaps?
Theres a couple of dimmers on the downstairs circuit. I have knocked all fuses off to all circuits bar the upstairs which hasnt got any
Reply to Problem with a timer fan on light circuit in the Lighting Forum area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
