Problem with a timer fan on light circuit | Page 3 | on ElectriciansForums
Discuss Problem with a timer fan on light circuit in the Lighting Forum area at ElectriciansForums.net
What voltage did you have on the Switched live when it was supposed to be off?
I tested with a Fluke T120 Its not supposed to give a LCD readout below 12 volts but if I switched the light switch on it read 247v and when off it went down the scale and rested at 9 v. I usually just get red lights illuminated and a buzzer at 12 volts on the scale on the meter. Which tells me its less than 12
Hi - thought was to try a small load from SL to N at the fan. Purpose is to clamp off SL to zero volts when light switch is open. It will only have effect if there is leakage through the switch or induced voltage from other cables. Good hunting !
My Fluke 110 gives me or sorts 'low' voltage readings, which I don't believe in :). Have you tried measuring this 9 volts with an analogue meter, before you get led up the garden path?
You've ruled out the fan as being the problem as far as I can see, so now you need to track down where the this 9V is coming from.
What have you measured the 9V with reference to, earth or neutral?
if you have a suitable multimeter then try measuring it with that, I suspect it will give a higher voltage reading.
I think the simplest explanation for a voltage on the S/L when it shouldn't be is that the switch is not operating correctly, so I'd be inclined to test that first.
If the voltage actually exists, as well as checking the switch, the remainder of the circuit (i.e. in other rooms) needs to be verified that its wired correctly. I had to fix a fault, where live had been connected into neutral and neutral vice versa.
methinks all threads regarding timer fans should themselves be on a timer, and self-destruct after 2 days.
Reply to Problem with a timer fan on light circuit in the Lighting Forum area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
