problems with test results | Page 2 | on ElectriciansForums
Discuss problems with test results in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Had this two weeks ago in a fire damaged bungalow. I know it sounds implausible to some but a neutral to earth fault on a circuit stopped the RCD from tripping and test button wouldn't work. Dissed circuit in question...RCD now tests fine and test button works.
You will more than likely get a higher Zs through an RCD due to it's own resistance and also the test meter puts out a lower current on the no trip setting so the result isn't as accurate.
Right i recon i have a n earth fault on a lighting circuit on that side of the red and also a crossed n on the other
I recon this is my problem hammy
Any ideas on the different zs values I'm getting from my dialog tester on the same socket chaps ?
@Loki 2.5 T&E RFC with a R1+R2 reading of 0.48 would give an expected value of 1.15 for r2 and 0.77 for r1.
1.15+0.77= 1.92
1.92/4=0.48
To work it out
0.48x4=1.92
1.92/1.67=1.15 for r2
1.92-1.15=0.77 for r1
You said that the Ze is 0.5
Im guessing its a tns & not tncs then as its over the 0.35 Ze max
If using 2.5 (1.5) T&E
Zs 0.98 - Ze 0.5 = 0.48
4 ÷ (2.5 + 1.5) x 0.48 = 0.3
r2 = 0.3 ohms
r1 = 0.18
Roughly lol, Am i close?
r2 = 0.3 ohms
r1 = 0.18
Are you answering post 3?
I seem to recall, I might be wrong, one of our more eminent members describing a situation where a neutral earth fault on a circuit could trip an RCD that is not protected by?
Reply to problems with test results in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Duh!!! Just re-read Op's original post, it was converted to a RFC!
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
