Had a Veritas panel do exactly the same recently, the only option was to ditch the program back to factory defaults and reprogram the panel from scratchI have reset it now with the engineer code but am unable to arm it using my personal code, it will arm in a fashion by pressing part/full but flashes up zones 5,6,7 whilst arming
Takes me about 10 - 20 minutes to reprogram a Veritas Excel panel including the text depending on what part sets the customer wants so a Veritas 8 would not take too longIs that an easy task to do, I've been looking at just buying a new control panel as this one is 20 years old now anyway
Please find attached manual....View attachment 26988
Do you have power to the panel, manual page 7 number 12Hi, I’ve just my Veritas installed and the power light is flashing constantly and the alarm won’t set…just beeps constantly..??
What changes have you made, without checking a manual I'm sure the quick setting feature is a programmed optionI have changes the Veritas C8 panel recently but for some reason, the alarm can be set by just pressing full or part without any user code which is unusual - any ideas on this issue?
It still needs the user code to unset the panel
In the installation manual section 4 programming the control panel, miscellaneous selections zero, option 3 single button setting the default is ONIt is an install of a new panel - yes it does need the user code to unset! Wasn’t aware of a quick set option and can’t see reference to it - Thanks for the reply
