Problems with veritas 8 alarm
Hello,
As a follow on to this topic, I was wondering if someone could assist with the following potential issue please.
We have a Texecom Veritas 8 System with a rather old and faded alarm box on the outside wall, although that said it still works fine.
Next month we are having a new rendered finish on the outside walls, which requires the alarm box to be disconnected and removed, prior to thereafter reinstalling with either the existing box or ideally a newer one, albeit still linked to the existing Veritas system.
Is this possible or will this cause major issues as highlighted in previous posts here.
Many thanks for any advice.
A new external sounder can be connected to your system with no problems if you take a picture of the connections before you remove the external sounder
You will need to insulate the +12v and -ve so you do not cause a short and blow the fuse in the panel
Many thanks for this reply.
