Professional Advice needed Re. Condemned Wiring | Page 2 | on ElectriciansForums
Discuss Professional Advice needed Re. Condemned Wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A landlord of a single occupancy dwelling is legally obliged to ensure the electrical system is safe, this does not necessarily mean an EICR. HMOs are different where it is a legal requirement to undertake EICRs .
This is a 3 bed detached house
I'm not familiar with the definition for single occupancy
What I mean is it is not being rented to more than one person whereas an HMO ( House of Multiple Occuoancy) is. Strictly speaking the only legal requirement in your case is to maintain safe electrical systems and not necessarily an EICR.
I'm with you, just looked it up.
Yes it's one family living there under one tenancy.
Thanks for the advice :)
Could be it was just was just a bit of a guess on a couple I've seen, was working in a street from 1964 and they wired the lights in VIR but everything else in pvc, very strange
I would say you are about 10 years out. 1950's ....
While it is true there is no explicit legal requirement to execute a PIR on single occupancy the fact that there is a requirement under a number of statutory rules to ensure electrical installations are safe, the only way to comply is with a PIR/EICR. By the sounds of the installation described by the OP these legal requirements my be being breached in which case there is a real possibility of legal enforcement.
Hello Electricians
I'm after some general but professional advice, figured this forum would be a good place to ask and would really appreciate some help.
My ex-partner recently mentioned in conversation they had an electrician round to look at changing some light fittings for ascetic reasons.
The electrician advised them that the wiring had been condemned and the house needs rewiring, I believe it's due to the age of the house. I don't know much more than this but I believe that based on this the electrician wasn't willing to work on the light fittings. I'm going to try and find out more tomorrow.
This is my daughter's home and I'm now concerned for her safety. Really just want an idea of the sorts of risks there might be in a house where wiring has been condemned.
Initial thoughts are that safety standards have been improved over the years, maybe modern appliances now draw more power... Possible fire risks?
Do I really need to be worried? If somebody could just lay out the potential risks, maybe give examples of why wiring might get condemned due to age....
Any help/advice will be greatly appreciated
Worried Louis
Louis
You need an Electrical Installation Condition Report (EICR) carried out, by a repibutable electrician, NOT by the guy that has condemned your wiring with a quick look, he more than likely is, as Tel says after a quick buck,
The EICR should higlight any problems yoy may have, don't know the costing in your area, but I think a couple of hundred should cover the report ( It's been a while since I did an EICR so my price may be off, others will be more accurate anyway the Electrician will quote before carrying out any testing)
Good luck
Hi,you cannot condemn any installation,purely on the an estimated age of the fitted equipment.
This HAS to be backed up,with further inspection,testing,and a specific explanation of why it is either not fit for use,or does not comply to any relevant rule or statute.
Just because something is old,does not mean it is not fit for purpose,or Vince Cables wife,would have had a new husband fitted.
The fact that the landlord has not chosen to have an electrical inspection,does certainly not,mean the property is dangerous. It does however indicate his lack of care and foresight,in opening up his risk of litigation,should it be so.
My parents property was built in 1963,and has had no rewire,a few additions,with one new DB,10 years ago. It is in fine order,and complies with all testing criteria and regulations,barring an iron DB,which it is not missing,as all connections were done correctly:).
My house was built in 1965 and everything was in TRS....the council must have had a load of reels in stock!
I believe you are right there @westward10 As far as i was aware the EICR does not apply to rented properties unless it is a HMO or subject to a council who only pay housing benefit to landlords who have agreed to meet certain standards, one being a EICR at certain intervals, complaints process etc.... Housing associations work to their own rules and normally do one before every tenancy. For private landlords the only thing is gas certificates and to make sure the electrics are safe and fit for purpose which is very much open to interpretation, although a eicr coudl be seen as establishing the safety.
The only way to prove that there is an issue at all is to have an EICR carried out as mentioned earlier. The fact that an electrician has pointed out something, whether right or wrong, has raised an issue. If it was me I would go to the LL with these concerns and hope that the LL will act. Cover yourself by txt or email just in case ....it is difficult when you know the LL. As it stands there is no direct legal requirement but still a duty of care.
I met one LL, in 2008 who boasted hundreds of properties around the UK. I met him at a ground floor flat he was about to purchase. I advised RCD protection for possible mobile equipment use outside...but would have to carry out inspection/test to get a better picture. He said he was not about upgrade all his properties to RCD protection (not my words) and BTW to prove duty of care in the courts is a very grey area.
I asked "do you know if that socket outlet has an earth or very high resistance?" He said "no why ?"...I said ..."I don't know either... until it is properly tested"....I walked away.
I have met a few LL's that do care and insist on a 5 year test...not many.
Reference the last question you were asked, the best answer would be with wittnesses is "hang on a minute I'll consult my Crystal Ball"
What worried me is that I know the landlord and they don't like spending money at all....
Cor blimey ..... stone the crows ..... blow me over .... strike a light guv ..... knock me down with a feather ..... a landlord who doesn't like spending money. Now there's a surprise.:eek:
Reply to Professional Advice needed Re. Condemned Wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
And metal backboxes partly full of pink plaster smacks of lazy DIYers, or equally lazy professional sparkies.
T
Is this bend in a PEX pipe too much? Hi, I by chance discovered that amongst a bunch of copper pipes, I have a PEX pipe that runs through a void...
techweb
T
