Profestional alarm install, mains supply 0.5mm2 flex into back of a socket | Page 2 | on ElectriciansForums
Discuss Profestional alarm install, mains supply 0.5mm2 flex into back of a socket in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Not complicated is it. Contact the installing Co, ask for the Minor Works Cert. If they haven't got one, say you require one from a qualified electrician. If they don't respond positively by providing a cert ( having made the alteration comply if it doesn't already), then it's off to their governing body and Trading Standards
But you should give them the opportunity to put matters right first - only fair.
so you are quick to judge a alarm company.
why could you not have done a alarm for you parents .and save them monies.
or are you not up to the job on fitting alarms systems .
My parents live 180 miles away, and the insurance company wanted one fitted by an approved alarm company. So I didn't want to be part of a support contract involving urgent 400 mile round trips and I don't belong to an alarm trade body...
by the way, where is the trunking lid you took of the trunking
and why did you use tipex on the pic to rub the installs name out .
if you quick to judge their job.
1. The lid was absent on my arrival.
2. I wanted to check the facts before giving the company a public grilling, and it wasn't tipex, it is called Microsoft paint.
If it is 0.50 then it is inadequate for the purpose of fixed wiring. If it is 1.0 then it is inadequate for direct connection to a ring final circuit assuming it is a ring final. Flexible cords/cables require suitable restraint at termination points.
Reply to Profestional alarm install, mains supply 0.5mm2 flex into back of a socket in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
