Pros...cons...preferences.. | Page 4 | on ElectriciansForums
Discuss Pros...cons...preferences.. in the UK Electrical Forum area at ElectriciansForums.net
Baddegg
Supporter
Patron
Southsea
after my rather vague thread Friday about finding the 30 mtrs of 10mm 2 core swa In the back of me van.....after some views on earthing to the shed, 3 options as far as I’m aware are
1. Run a single 10mm from main met upto the shed and use that
2. Use the armour of the swa, adiabatic permitting..
3. Connect the swa to the main met at source end and TT the shed
Each option is appruthe same cost wise and it’s my own house so Labour is not a big issue, as per title just after others views and preferences....
Depending on which body you talk to the armour on swa is acceptable to cable that has cores of 95 mm and under but it's never a bad idea to bring A10 g/y with it
I’m just going to remind that 10mm twin and earth typically comes with 4mm of copper for its cpc.
Need some of the cool Irish stuff. Got some 16mm t+e here, 16mm CPC.
[ElectriciansForums.net] Pros...cons...preferences..
Reply to Pros...cons...preferences.. in the UK Electrical Forum area at ElectriciansForums.net
