Protecting armoured cable | Page 3 | on ElectriciansForums
Guest viewing is limited
Discuss Protecting armoured cable in the UK Electrical Forum area at ElectriciansForums.net
sparksburnout
Nearly Esteemed
Notts
Yeah I know it's an odd title. Currently looking at a job where an SWA runs down a garden to a shed, but it is just laying on the ground and looks rubbish. I am guessing the last installer left it like that due to the difficulty in burying it, so at least you can see it........ The only run is between stone/concrete and a line of old trees that have been cut down to ground level, there is no way I am going to be able to get down 600mm or anything like it as the roots are going to spread out, there are about 15 old stumps and It would be near impossible to dig them out. So, any ideas of the best way to protect the cable in a shallow trench? Is it possible to contain it in some kind of galvanised metalwork, or cap it with stone or similar, to prevent spades/forks and the like from penetrating it? I am only going to have a narrowish trench and I am guessing it is only going to go down maybe 150mm? Obviously the SWA on its own is not going to provide enough protection.
It is a common misconception that the term 'armoured' when applied to a cable means that it is somehow impervious to mechanical damage, it is not. A slight scratch of the outer sheath is enough to ruin the cable.
if rough sparks or labourers pull it in then it wont be long before the armour rusts through and water travels down the cable
Do me a favour.
All that would happen, is that the steel wire would start to corrode.
Hells Bells, and there's me having conducted thousands upon thousands of sheath tests to SWA cable over the years, and now i find i've been wasting my time!!
Come on Spin, that's one of the daftest answers/statements i've ever seen you post!!!
Reply to Protecting armoured cable in the UK Electrical Forum area at ElectriciansForums.net
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
Recommended Sponsor News
Hi everyone,
