Protective conductors on an EIC | Page 2 | on ElectriciansForums
Discuss Protective conductors on an EIC in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Protective conductors would cover circuit protective conductors (cpcs) and the earthing conductor at source of supply. As there is no mention of main protective bonding conductors it probably includes these as they are also protective conductors.
I tend to agree looking at the form the OP has provided, the one I looked at mentioned all 3 for the presence of:
Protective
Bonding
Earthing
Makes you wonder how some folk can get confused
The Easy Cert form your using appears to refer to both cpc's and main protective bonding conductors in this one tick box. The one I use has separate tick boxes. Whatever you would of carried out some tests to verify, and for cpc's have a specific reading.
you are correct there.
on that test sheet 13.2 on BYB 3.0to 3.8 /earthing and bonding arrangement's 411.3
but the person who made that test sheet should have made it more plain with out
copying the regs for copy righting.
I know you guys are banging your heads, but I just wanted to clarify.
So thank you all for your input and help.
Check out Chapter 54 543. 2 Types of protective conductors that will confuse you even more
The ones in the BYB are just models, you can have what you want. It could have the recipe for beef bourguignon, if the author thinks it relevant :)
Reply to Protective conductors on an EIC in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Personally, I would just put them in the observations, the inspection schedule is not exhaustive.
Yes, supply via buried SWA from the main dwelling into new CU. The main house is TT. New CU to have RCBO on all circuits. The workshop area will...
