ringer
Can you use main incoming L&N as known voltage source instead of a proving unit?
Discuss Proving dead at the CU in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I wouldn't as what if your test lamp said it was dead and it wasn't because you have a duff test lamp?
if you are doing the ze test you have no choice then to work live so you might as well do the proving at the cu when testing for a dead cu to perform r1r2 tests ect.
edit my proving unit don't light up, my voltage tester dose.
Reply to Proving dead at the CU in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
