Proving dead at the CU | Page 3 | on ElectriciansForums
Discuss Proving dead at the CU in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
So if you're up for assessment, and you're working on a CU, and you have to hand a readily available 'known source'. But if you don't own a proving unit, is the assessor going to say 'what happens when you're not at the CU, how will you prove dead if you don't own a proving unit?'?
I have a Fluke T120 Voltage/Continuity Tester and my proving unit is a couple of 9 volt batteries in a plastic box with terminals attached to two bolts (screws) showing out (yes, you got the idea) - a cheap & cheerful proving unit.
Works wonders every time!
Reply to Proving dead at the CU in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
One thing that maybe is worth a mention is to always put the probe on E or N first as depending on the impedance of the instrument, once you...
View: https://www.youtube.com/watch?v=glsg2HpWyok
