Pulling the Main Fuse (Poll) | Page 8 | on ElectriciansForums
Discuss Pulling the Main Fuse (Poll) in the UK Electrical Forum area at ElectriciansForums.net
H
hightower
So, anonymous poll - who pulls the main fuse when required (ie CU change) and who get's the DNO/supplier/whoever in to sort it?
I have pulled the fuse every time and only had one time when someone turned up and said what are you doing. Turns out they had wired the mains wrong and the main fuse turned off the house I was working on and next door. The neighbour rang them as they had no power.
I explained what I was doing and showed them my Napit id badge and they said no problems we will call at some point and correct it. That was 3 years ago and it's still like that.
I work for the board, your not supposed to pull the main fuse. But if there is no double pole present to isolate, what do you do. I have never known any board members going out pull a mains fuse so the sparky can do his work? I have caught a couple of sparkies over the years, doing this, but I've never said nowt or reported it, because how else would you do it. If anyone has a problem with there cut out, vir present, sealing tabs snapped, sharing a mains fuse, damage, leaking pitch, etc. Go onto the Electric boards website and log it on there as a CRM job. The board will send some one to look at it and change it for you.
Reply to Pulling the Main Fuse (Poll) in the UK Electrical Forum area at ElectriciansForums.net
sounds like one of those jobs to swerve and let it be someone else's problem
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
