Pulling the Main Fuse (Poll) | Page 7 | on ElectriciansForums
Discuss Pulling the Main Fuse (Poll) in the UK Electrical Forum area at ElectriciansForums.net
H
hightower
So, anonymous poll - who pulls the main fuse when required (ie CU change) and who get's the DNO/supplier/whoever in to sort it?
Yeah exactly, I was replying to the above poster "Did a Ze reading which came out at 0.16, so didn't comply (tns)" but my point is that's an excellent reading so I don't know why it doesn't comply.
you know what, your absolutely right. It must have been the gaping hole in the fuse housing that caught they're attention
The dno's really need to get there act together and approve a scheme like SSE for electricians to pull fuses then crack down on people who aren't approved. I will say that using the correct ppe is essential though, this happened when one of our technicians pulled a cut out fuse.
[ElectriciansForums.net] Pulling the Main Fuse (Poll)
so what would be considered as the "official" ppe for this
If you work for the metering companies or dno it's normally full face visor and LV gloves (leather over gloves if required for mechanical protection) and clothing should be flame retardant. When we do work on the large metal clad heads (up to 600 amp) overalls as well and those are arc resistant.
And I looked over the shoulder of someone pulling one - I'm sure there were seals before pulled.
Given the grand advice of pocketing the fuse carrier to protect yourself from idiots playing a trick and not thinking about the consequences.
Reply to Pulling the Main Fuse (Poll) in the UK Electrical Forum area at ElectriciansForums.net
sounds like one of those jobs to swerve and let it be someone else's problem
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
