Leesparkykent
Nearly Esteemed
Does anyone know what brands make downlights wit push fit connections? looking for speed when it comes to fitting them 2 x 1.0mm cables. Fire rated down lights not integrated fittings. Cheers
Discuss push fit connector downlights in the UK Electrical Forum area at ElectriciansForums.net
Cheers mate. yeah go on?I don't know of a GU10 option that does a push fit. However if you are making off 2 twin cables then I can recommend iCage by Ansell. They do a standard and low rise version. The terminals are huge and the cover is also the cable grip, very speedy to connect.
Would you be interested in an integrated fitting at not much more of the cost of a decent GU10 and LED lamp that utilises push fit connectors ?
I don't know if they are any good nor if they take two cables but a brand called Axis do GU10 fire rated downlights with push fit connectors, also the Saxby Shield range uses push fit connectors, again not used them so can't comment on their quality.Does anyone know what brands make downlights wit push fit connections? looking for speed when it comes to fitting them 2 x 1.0mm cables. Fire rated down lights not integrated fittings. Cheers
I know the integrated LED ones do but haven't fitted the GU10s, do you mean them as well?[/QUOTE]QUOTE="tomspark93, post: 1206778, member: 72309"]I think the jcc fittings have push fit connections.
Ditto the JCC FGLED range has push fit connections for 2 x 3c (1.00mm be ideal size), and push fit cable clamps (i.e. no screws).I think the jcc fittings have push fit connections.
Knightsbridge do a gu10 fire rated with cage push fit terminals, I often use them and are quick to fit with no screws on cord grip either.
Reply to push fit connector downlights in the UK Electrical Forum area at ElectriciansForums.net
