R
richardsolway
Hello all. I have a really puzzling fault at a property. There is a 16th edition Dis Board onsite with a 100a 30mA rcd protecting the front end. The Installation is TT. I wired a new extensions to the property in 2005 and oversized all earthing to adhere to the prospected 17th edition. There have been no alterations or additions since its completion. Recently the property has experienced the main 30mA trip operating and with this, there seems to be no specific circuit causing it. I have been over and completely tested every circuit. The lowest IR reading was still above 10 MegOhm and was an original circuit to the house. The RCD its self tests OK with it not being to sensitive or beyond maximum disconnection times. The ZE reading a the the board is 95 ohms (TT). Apon functional testing or circuits and then blanket testing between the neutral and earth bars inside the board I had a reading of 0.00Megohms. This is with the main switch closed (On) and all MCBS open (off). That's the background and now for the question. If this were a TN-C-S Supply you would expect a reading like this as the neutral and earth are connected within the cutout and at various intervals tapped to earth on the lines. However this is a TT supply, I can seen the main earth for its entire length to the Rod outside and has no physical connection. Has anyone else experienced this? The overhead supply pole is 40m away and then passes underground before rising up the neighbours property and across the facia. The poles are not marked PME and the supply authority will not comment on it either (Western Power Dist) as the general state of the services down here in cornwall is poor and they will no longer guarantee an earth to a domestic property. The neighbours property is TT also and their Rod is 30m away from this installations rod. The transformer is 3/4 mile away also. Thanks in advance to anyone that can give any hints or tips to try. (I have also carried out IR with equipment installed and lighting in the on position (naughty I know) and this did not indicate any different readings from the norm). Thanks Again. Richard.
