Puzzling installation | Page 2 | on ElectriciansForums
Discuss Puzzling installation in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I knew I'd read of this before once.
Some interesting comments about the span between metal conduit and the earliest PVC, apparently the cpc's were sometimes connected to the conduit using a threaded earth coupling.
1957 is suggested.
That links not working for me for some reason - what's the thread title?
Sounds about right - I guess it's better than it being VIR... And too early for green goo too...
It doesn't let me link to IET forum:
[ElectriciansForums.net] Puzzling installation
Yea I can’t open the link but I understand what you’re trying to display by the wording. I’ve come across a few older installs which were wired in singles and earthed through the conduits. Was great when I was rewiring them. Tied on and pulled through new pvc twin and earth and got paid per property these properties with conduits earned me mega £££ and the boys I worked with enjoyed the ? when we finished early ???
Ah yes, I'd forgotten that certain other forums are blocked, however sneakily you try to list them....
The house is older than that, but may well have been rewired from the original conduit installation - though no surface signs left of conduit - it might be hidden behind the skirting board I guess....
But that begs the question as to where the conduit is earthed - the Zs is too low for it to be acting as a rod, and possibly even too low for it to be directly using any pipes - but the main bonding may be increasing that.
The water main bonding wasn't visually available, just to add to the fun, though verified by testing...
If it is late 50s wiring then it goes to show how good comparatively PVC is since there was very little sign of 'aging'
What did the 13th say about RFC cpcs I wonder?
If this is run from a 'genuine' source, rather than via extraneous bonding, then can a single suitable sized earth at each point be considered safe for fault protection on an RFC? and if so what is that size?
Dropping it to a 20A radial would not be a major problem to be honest - it's 7 sockets in total - and the whole property is on a 60A fuse in any case...
Taking your max Zs of 0.38, so fault current of 605 amps, I think I'm ending up with 3mm csa using adiabatic. I believe you said somewhere between 2.5 and 4mm.
I'm also reflecting there should be a way to tell the equation you've had 3 cans of 1664 though, so you'd better check my maths....
like your style. 1664 is 1 of the few available lagers that are drinkable.
Reply to Puzzling installation in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
Ok I’ll try this when I’m down
