PV electrical certificate price ? | on ElectriciansForums
Discuss PV electrical certificate price ? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
A
andreas
Hi all. I am a small subcontractor. One of my client asked me about the price for the PV electrical certificate ( just for the AC ) . I had no ideea how much cost and where do i have to find somebody to come and test . Any ideea ?
Shurely AC certificate is just the electrical installation cert plus schedule of tests, inspections etc. If you have Part P certification then you can do a domestic AC cert!
I am a general refurbishment sub. Im not a qualified electrician, but i know about. My client asked me to find somebody to certify his PV installation ( only the AC side, the other part has been done ).
You need a registered electrician, any electrcian more or less can certify the AC side for you, not sure about price, cant see it being much.
it has to be an IEC and schedule of inspections, has it been registered with building control? if not you need to get your spark to sdo that as well.
Surly the electrician will have to test all the DC side of things, and all the relevant tests that are required for a PV system, not just connect up the AC as that would make the system non compliant?
An electrician can test & legally certify the AC installation. He needs to have been instructed by the owner/manager of the installation. The DC side does not have to be tested for this. just like when you test a shower or cooker circuit, you dont test the appliance itself.
Reply to PV electrical certificate price ? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
OLEV is now OZEV, in case you weren't aware. Installing EV equipment is not as straightforward as many might think. There is a Code of Practice...
loz2754
L
Welcome to Electricians Forums :) Thanks for signing up. :D
