T
thushar
I don't have hot water cylinder but have a boilermate 2000, I am buying a new car this year and was looking at Vauxhall Ampera hybrid car could charge it when not used with is device?
Mark II switch from Intelligent Solar PV Immersion Heater Switch - Use Surplus PV Power to Heat Water, the same guys are behind the SolarImmersion (SolarImmersion ? Surplus Solar Energy Water Heater |) could do the charging on the electrical car. It have inbuilt DIN rail that can take a relay to extend the switch capacity (to about 50A). With that you could charge the electric car from your solar PV surplus.
Looks like Mark III / SolarImmersionfrom is similar to immersun, so can take only resistive load - so probably not suitable for electric car recharging.
