there are other threads explaining this more fully, but that side of things shouldn't be a problem as once the RCD trips all the circuits then lose their return earth fault path to the inverter, so those circuits effectively become protected via the separated circuit method for those 5 seconds... or there's no circuit back to the inverter from an earth fault, so any problems caused by the earth fault will automatically cease to be a problem.
There are apparently some issues with certain TL inverters causing the RCD units to stick, presumably due to too much DC leakage current. I think someone posted up about the Samil inverters likely causing issues as they allow for much higher DC injection than the SMA, or Aurora - not sure on the Fronius.
It's certainly not best practice, and we don't do it, or recommend it, but it's not necessarily actually dangerous as long as it's not interfering with the RCD function itself.
