Just to note to this thread, Heavy duty PVC can have a higher impact resistant than steel conduit as some of the impact energy is reflected and if it does shatter it absorbs the impact diverting it off the cables, where a steel conduit can be buckled crushing the cables with a like for like impact, the issue with plastic is that it tends to be left in this state if all is still working but we all know it should be replaced straight away, and ive used high impact pvc and believe me it takes some hitting to even crack it. So regarding O/P high impact pvc conduit is ok unless the tools been used are like angle grinders where an accident would see it cut through it like butter, in this case steel conduit should be used. If the site is industrial with heavy work and high chance of accidental damage you just need to work out what is likely to be the cause if your balancing between high impact pvc and steel. A company with a record of damage to electrical infrastructure should have their electrical inspection shortened to a max of 3yrs or even less if damaged electrics are constantly been replaced and call out on.
