PVC or Galv 20mm Conduit | Page 3 | on ElectriciansForums
Discuss PVC or Galv 20mm Conduit in the Australia area at ElectriciansForums.net
hi there
after a lil advice re overhead supply to an out building. The outbuilding is no more than 1.8 meters from the house surrounded by a tarmaced drive and concrete paving (hence overhead route). Maximum height is 2.6 meters from point to point entry,which i know is below the 3 m minimium requirements but common sense must be appplied, i intend to supply via conduit. Now the regulations state the use of steel conduit but do not mention if PVC conduit can be used.Now i understand the reasoning for steel conduit to provide impact protection. i was wondering if anybody had any thoughts or advise re using PVC conduit for this short run where due to location there are no impact risks.
many thanks
I have used the MT Supertube on rolls and found it time consuming when straightening it so I designed and got a dispenser made for the rolls of Supertube which you draw of the length you require. Quicker to install than screwed steel conduit.
I have saw a gadget like this being used by plumbers who were installing a pipe that looked very similar to super tube. Very good idea, as I say, super tube can be a nuisance to straighten.
Reply to PVC or Galv 20mm Conduit in the Australia area at ElectriciansForums.net
