Pyro feeding domestic db | on ElectriciansForums
Discuss Pyro feeding domestic db in the Domestic Electrician Forum area at ElectriciansForums.net
H
harryharman
Carried out loft extension in old ladys house, normally install sub-board just for loft supplies but she wants her old db (3036 fuses) changed for a new one and loft circuits installed all in new split rcd board. Ok fine done this few times before but at this house, the head is in the front garden with a pyro coming out feeding her db. Any suggestions as to what I should do in terms of replacing the pyro as I dont think its a good idea to still use?! Any help is much appreciated, thanks in advance.
I don't really know much about pyro, never used it- it doesn't look very big and it must be 50+ years old, I just thought if I'm changing the board I may as well sort out the supply cable as well?
Don't change it if it tests out ok
Why isn't the pyro any good for continued use??
My thought as well would probably outlast anything you would replace it with
I think now might be a good time to learn about Pyro and it's operating characteristics before ignorantly dissing it. How have you identified it's age if you don't know that much about Pyro
Pyro can take more current, it might be up to the job you never know. It's CCC is in the regs! Might not be as old as you think. Good stuff.
It's a shame that the qualities of Pyro don't seem to be highlighted during training these days a lot of very serviceable Pyro has probably been ripped out in ignorance in the last few years
It might very well be ok, as said test. 6mm2 heavy duty rated (clipped direct) at 70A. And it probably looks smaller than you'd expect.
Btw I have v. Little practical experience of pyro too, just testing of, mainly!
Ok that sounds better, I'll do an IR test on it and hopefully it will all be ok, but I think the earth coming in with it is only a 10mm so I'm pretty sure ill have to upgrade that anyway? Also how do you know what size pyro is, is it normally marked on the cable?
Reply to Pyro feeding domestic db in the Domestic Electrician Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
