J
james king
can any one give me sum examples of the king of questions they will ask me.???
eg why do zs test things like that???
Discuss Qs on assessment day ?? in the Business Related area at ElectriciansForums.net
When I did the practical, there were three different mock-up boards. One one you had to do all the standard tests, on the second you had to do the visual, and on the third they would tell you that there were 12 faults and you had to list them all. some of the less obvious ones were bend radius of cables, using one clip for two flat cables side by side, that sort of thing.
In the written exam, they might ask why the value of PSCC is important when selecting a protective device
what is the breaking capacity of a 3036 fuse, and what a ring continuity test can actually tell you about the circuit itself apart from R1+R2.
A lot of us found that we already knew the answers but had forgotten them over time and this was a handy refresher.
hope this helps
Have you any biscuits to go with my tea? Is that motorbike a ktm? my assessor was very laid back and the worrying i did for weeks before was for no reason, he just asked things about the regs which you could look in the book for, what do you check for before you alter a circuit or add a circuit just things like that, he's not looking to catch you out but just wants to know you're competentcan any one give me sum examples of the king of questions they will ask me.???
Did you put a switch fuse at the start of the tails?the job i am showing him is a flat re wire so not really any long cable runs. yes but there must be a point at witch they fail you. would they ask for tail lenghts that i brought feed into CU from down stairs
Is it fused, smaller than the main fuse?yes it can all be isolated
Yes I think its on a 80a isolting fuse. Main fuse may be 100 not 100@er cent sure?
Reply to Qs on assessment day ?? in the Business Related area at ElectriciansForums.net
