You need to start by getting the 18th exam ....
And doing EICRs is boring , cut throat, and very unfulfilling
Appreciate your posts pal. Your genuinely trying to help and not trying to make a mockery out of anyone. Thank you.
I understand people want to protect there trade, less newcomers = less competition. The ones that tend to help are far to establishished to be concerned with newcomers like my self. Same thing with the current field I work in...
I don't think anyone is worried about newcomers coming into the trade. I for one welcome them
It's just were tired of seeing people coming into the industry and expecting to work for themselves unsupervised and filling out reports deeming someone's home is safe or not
I've got 7 years experience and I wouldn't want to do an EICR on my own without someone with more experience than me. Especially when all of my work has been new build installs. I couldn't possibly get the experience needed to carry out an effective EICR of property built in the 60's for example.
I'd just end up one of those cowboys who suck air through their teeth and just say it needs a rewire because I've seen an old fuse board
My advice is get yourself on site, learn the trade by becoming an electricians mate/improver. You'll be learning everything from how to install metal containment, to wiring a house all the way to testing and fault finding.
Then complete your NVQ level 3 so you can be a genuine qualified electrician. Then do the inspection and testing qualification with Ableskills (I did mine there)
Then hopefully you'll be ready to be out there on your own
No disrespect to you but you'll be a better electrician this way and will have the skills needed to make your customers happy and in turn make you more money. You can be better than every other Tom, Dick and Harry thinking their "pukka at lectrikz'
I am just wondering why you believe eicrs are worthwhile setting as your goal?
As Murdoch stated it is a cut throat market
The tick box companies and individuals and the prices available tend to deprive the market of the very people who are best able to test and inspect,good quality experienced electricians who try and do a thorough and competent job of eicrs
Unfortunately its generally left to less experienced people starting out to fill the market,consequently the prices are rubbish
With Napit you would require the 2391 test and inspection or the two part modern equivalent.
You would also be required to hold public indemnity insurance
If you do still want to pursue this path,the IET recommends that electricians who carry out eicrs should have above average knowledge and experience of the installations that they intend to test and inspect
This is a pipe dream by the Iet,nevertheless it shows what level you should be at before doing test and inspecting
Otherwise you will just be adding to the overwhelming amount of eicrs carried out by those who are least able,but good luck with your aims
Sign up as a Mate or Improver with some Agencies.
You’ll need to get the 18th and an NVQ3 to enroll with any Part P scheme. Probably also need the 2391 to sign up to conduct EICRs.
Derby
Trainee Electrician
Qualifications needed to register with Napit as EICR electrician
NAPIT Certification Scheme
Certification NICEIC, NAPIT, Stroma, BECSA Forum
LabourForApprenticeship,
suffolkspark,
