Query wiring on house purchase. | Page 3 | on ElectriciansForums
Discuss Query wiring on house purchase. in the UK Electrical Forum area at ElectriciansForums.net
A5TR4L
London
Hi everyone,
Just purchased a new place and have already stripped out all the rooms as plan a complete renovation.
Whilst everything is bare I wanted to ensure nothing seems amiss with the electrical side of things. Previous owner had the house re wired a few years ago and the sparky even left a floor plan of how everything is hooked up.....she didn’t have a receipt or proof of work so just want to make sure everything sounds ok.
So the CU is a metal cased 10way Crabtree unit with Iso switch and has been fitted completely with rcbo’s, so most things are on their own circuit.
So.
32a RCBO for downstairs sockets set in a radial circuit with 2.5mm T+E cable.
32a RCBO for upstairs sockets set in a radial circuit with 2.5mm T+E cable.
6a RCBO for downstairs lighting, loop in/out setup on 1.5mm T+E cable
6a RCBO for upstairs lighting, loop in/out setup on 1.5mm T+E cable.
6a RCBO for combi boiler in 1.5mm T+E cable, which goes to a 3a fuse switch in wall which then goes to boiler.
32a RCBO for cooker in 6mm T+E cable wired into a double pole iso switch before cooker. Cooker rated max at 16kw
20a RCBO for fridge on 2.5mm T+E cable
I’m no electrician just writing what I have in front of me, the house is quite small so cable runs aren’t that long and from what the previous owner told me all wiring has been fitted with plenty of air and not through any insulation etc
So at a glance does that seem to be ok, I’d rather get some opinions before i start fitting walls/floors as you may see something that should be re looked at.
Thanks for your time.
I always try to see the best in people, possibly to my detriment sometimes...but a possible explanation is the use of touch screen smartphones. I know I have been at home looking at this forum on more than one occasion, whilst half dozing after a busy day, and accidentally rested my sleepy finger on bad spelling or dislike etc. And when I wake up 30 minutes later I find an alert asking why I disagree with a post I agree with! So it might be trigger happy smart phones Pete.
I got a bad spelling one tonight mate.
Think you are being too kind.
Thanks for all the input guys, I’ve got a sparky coming round in the new year.... did call up the old owner to query who/what/when etc......pretty much the response ‘me speaky no engrish’ lol so, all I can assume is a friend of a friend of a friend of a friend did the install maybe on the sly to get the house on the market, either way atleast someone is coming to asses everything.....let’s hope there’s no hidden surprises laying in wait. Have a fantastic new year and thanks for all the advice :)
Dave, love that you got tax-deductible gifts for christmas! That's romantic!
I'm actually well chuffed mate, my Mrs puts a lot of thought into these things and I have enough socks and after shave to last a good few years.:D I also got a lovely new motorbike crash helmet,Shoei GT Air which is real quality so I've been very fortunate this Christmas. :)
Thanks for all the input guys, I’ve got a sparky coming round in the new year.... did call up the old owner to query who/what/when etc......pretty much the response ‘my sparky no engrish’ lol so, all I can assume is a friend of a friend of a friend of a friend did the install maybe on the sly to get the house on the market, either way atleast someone is coming to asses everything.....let’s hope there’s no hidden surprises laying in wait. Have a fantastic new year and thanks for all the advice :)
Just corrected that for you....;)
Happy new year everyone!
So I had the electrician around this morning, he proceeded to do his tests at the sockets and consumer unit etc.
At the end he said all the tests were fine, everything appeared to be in good shape. To issue a cert he did say that he would need to inspect all parts of the cable runs that aren’t currently visible since it’s his reputation/job on the line etc which I fully understand, so I’ve booked him in next week to do the destruction he needs to do etc to be able to sign everything off.
The only thing he mentioned that was a little odd when he saw the notes that I mentioned to you guys in the very first post was the cooker was put on its own circuit 32a rcbo using 6mm cabling yet the cooker (came with house) is fully gas operated which he said was crazy overkill. Other than that he seemed happy with everything.
Is it ok to leave this cooker on this circuit? I may plan to go induction once the house is finished, but In the mean time is it ok to run this low powered cooker on such a beefy circuit?
Thank you.
Thank you.
This Electrician that visited your House was or is he registered with any of the Competent Persons Schemes, NICEIC, NAPIT to name a couple?
How much did you pay for his first visit and did he issue you with a certificate (an Electrical Installation Condition Report) EICR for short.
He is going to come back an inspect every cable in your house? quite frankly he is talking out of his bottom. An EICR should take the form as described in the best practice guide. Hope this helps please let us know how you get on.
I would suspect the original Cooker circuit in your house was an Electric one hence the 6mm cooker circuit, if you are connecting your gas Cooker via a 13 amp socket outlet then the fuse in the plug top will be sufficient protection.
  • BestPracticeGuide4-Issue3 EICR.pdf
Hey,
He was Niceic registered and charged £25 to check each circuit in the house.
I was a bit confused, because of what he said I assumed since he didn’t fit the installation he wouldn’t sign it off until he verified that everything was ok In terms of cable runs being routed adequately as he mentioned something about the way cables are routed can affect how they perform, which could dictate what rcbo will protect them.
So reading your reply is there 2 separate certificates that are issued EICR as you mentioned which verifies everything is in good working order, and I assume there’s a separate one that is issued to show the work has been completed by a professional to meet regulations? If so should he have issued me an eicr regardless of whether he can sign the work off?
With regards to the cooker it plugs into a cooker socket. 3 pin socket on the right that the cooker plugs into and on the left a red isolation switch. I believe the 6mm cable runs from the back of this socket to the consumer.
Hey,
It's been a long time since I retired, so my facts may be a bit outdated, He would complete the EICR and through his Scheme (NICEIC) who would do what is required, what is worrying me, is you saying he is coming back to lift up boards etc, he should issue you with a copy of the EICR, one copy for his records and one copy to his scheme, if you are concerned at all, then I suggest you give NICEIC help desk a call and clarify matters, after all if he is registered with them they should be able to advise, me personally, from what you say, I'm not that sure of this Guys competence.
Thanks Pete I’ll give them a ring just incase. He came highly rated on all the trusted trade sites so I thought I’d be ok. Maybe because I don’t have the cert of when the install was done he can’t issue me anything till that’s there? I don’t know, I’ll give them a call and see what they say. Thank you.
Ah "trusted trader" now there is a misnomer. An EICR is what it is a condition report on the install as is, he should give you a cert. Give them a ring and take it from there
Trusted trader :eek: oh my oh my,you are definitely off to a bad start if you want to get things done satisfactory :(
The electrician looking at your installation should not be issuing you a "certificate"
The electrical installation certificate can only be issued by the installer of the wiring ;)
You need a report,its called a EICR,it should inform you and any interested parties on the condition of your installation :cool:
Unfortunately there is no requirement that restricts any person from doing that report,only that they consider themselves competent :eek:
Reply to Query wiring on house purchase. in the UK Electrical Forum area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
We just left it as it was, again the customer didn't seem too bothered, dont think she wanted me digging any further.
