Query wiring on house purchase. | Page 4 | on ElectriciansForums
Discuss Query wiring on house purchase. in the UK Electrical Forum area at ElectriciansForums.net
A5TR4L
London
Hi everyone,
Just purchased a new place and have already stripped out all the rooms as plan a complete renovation.
Whilst everything is bare I wanted to ensure nothing seems amiss with the electrical side of things. Previous owner had the house re wired a few years ago and the sparky even left a floor plan of how everything is hooked up.....she didn’t have a receipt or proof of work so just want to make sure everything sounds ok.
So the CU is a metal cased 10way Crabtree unit with Iso switch and has been fitted completely with rcbo’s, so most things are on their own circuit.
So.
32a RCBO for downstairs sockets set in a radial circuit with 2.5mm T+E cable.
32a RCBO for upstairs sockets set in a radial circuit with 2.5mm T+E cable.
6a RCBO for downstairs lighting, loop in/out setup on 1.5mm T+E cable
6a RCBO for upstairs lighting, loop in/out setup on 1.5mm T+E cable.
6a RCBO for combi boiler in 1.5mm T+E cable, which goes to a 3a fuse switch in wall which then goes to boiler.
32a RCBO for cooker in 6mm T+E cable wired into a double pole iso switch before cooker. Cooker rated max at 16kw
20a RCBO for fridge on 2.5mm T+E cable
I’m no electrician just writing what I have in front of me, the house is quite small so cable runs aren’t that long and from what the previous owner told me all wiring has been fitted with plenty of air and not through any insulation etc
So at a glance does that seem to be ok, I’d rather get some opinions before i start fitting walls/floors as you may see something that should be re looked at.
Thanks for your time.
Kinda old thread now, but how did OP get on?
Did new spark go to the effort of checking the full length of every cable?
An EICR would give enough info for him to say its 'satisfactory' and put your mind at rest. Doesn't involve pulling up floors etc.
What about the 2.5mm radials? were they 4mm radials, or 2.5mm rings?
Reply to Query wiring on house purchase. in the UK Electrical Forum area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
We just left it as it was, again the customer didn't seem too bothered, dont think she wanted me digging any further.
