Question about cable and security light | Page 2 | on ElectriciansForums
Discuss Question about cable and security light in the UK Electrical Forum area at ElectriciansForums.net
Daz134
Uk
Hello
We have purchased a security light LINK TO LIGHT
Im looking at adding this light with Flex cable of a run no more than 10 meters on a 3 AMP 3 pin plug.
I would have thought that 1.5mm flex cable will be over kill for this light due to the 1.5mm flex being up to 15 amps in current.
Would I be ok using a smaller cable of 1mm or even 0.75mm flex with a 3amp 3 pin plug?
I would appreciate your thoughts
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Thanks for the advice
When buying that cable should I go with 0.75mm, 1mm or 1.5mm
I think you will find the smallest is around 1.5mm, but these folk do 1mm:
For the sort of length you need, the postage is probably bigger than the cost difference in cable size!
You might find a CEF locally and they do 1.5mm (if they are in stock) so collecting might be best:
Great thank you
Would you suggest going with 1.5mm and not 1mm or even 0.75mm
Reply to Question about cable and security light in the UK Electrical Forum area at ElectriciansForums.net
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
This is an interesting issue. I agree with you however I took this to task with a scam inspector some years ago and we agreed to disagree that...
