OP
44ALLAN
In tp-n boards is it not 4 pole mcb as main switch? Or isolator
Depends what you want to do.
Some have a 3 pole Isolator and Neutral bar separate.
Others have 4 pole RCD's..........there's a few permutations.
Discuss Question regarding 4 pole MCB in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I thought main switch has to be 4 pole = isolate all conductors...
only for a domestic do all poles need to be switched at the supply origin.
i never fit a 4 pole switch in commercial db , i've seen the mess it makes if the neutral contacts fail while installation is energised.
I agree but, without tempting fate, I can't remember the last time an Rcd tripped ! ( maybe I should test them they might all be stuck eh!! ) lol
The 3 phase boards in question have them as their main switch and until I get any nuisance tripping their staying that way.
Not quite sure i'm understanding you here. Are you saying the main switch/isolation for this DB is a Straight 4 pole RCD or 4 pole MCCB with earth leakage protection incorporated!! To be honest, i've never seen a commercial (or otherwise) 3 Phase DB with an RCD used as it's main switch!! Normally it'll be a straight isolator switch or an MCCB, (with or without earth leakage protection.)
Like you said in an earlier post you can virtually make up any type of board you want nowadays with any configuration.
CEF own brand Proteus supply boards with rcd main incomers...........BX4R30 check them out.
All my 3 phase boards are fed from a local Switched Fused Isolator and over the years a few 'non-critical boards' have been left with a front end 30mA RCD covering all circuits..........eg the welding bay with one guy working in it with a few plugs and a radio dotted around the place
Never had a trip in 20 year so can't see the point in RCBO'ing the separate circuits to be honest.
Didn't say DB's Don't come in this configuration, i said that i've never seen one!! lol!! Must be tiny welder if a 30mA RCD holds in, either that or it's shot!! I wouldn't have had a welder on an RCD in the first place, especially a 30mA unit lol!!
Reply to Question regarding 4 pole MCB in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
