B
beaver74
on a pme system wre a rod is used to seperate metal parts from pme terminal how would you record r1+r2 of cpc conected to rod and r1+r2 of cpc conected to pme terminal ie swa
got some external lighting in midle of a lawn wired in swa and armer is continious but seperated from fitting metal work so that swa will have a good earth loop reading
earth conductive part of lighting is conected to 3 rods spead around circuit via 3rd core of swa so as to seperate from pme terminal but the circuit will have rcd protection at the main intake so r1+r2 of swa and r1+r2 of lighting circuit on the rod can not be recorded together as they are seperate
