R1+r2 test | Page 2 | on ElectriciansForums
Discuss R1+r2 test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi Guys i have traced the fault back to the first socket,the cpc between the cu and the first socket is broken so i need to find the break.The bathroom rad was sup bonded to a socket on this circuit so i guess i got a reading via the water pipe.Does that make sense?
Cheers
Haj
For info, no problem with Sup bonding to a socket to get an earth. It's a common way of bringing R1 R2 down by having as many parallel paths to reduce the resistance.
I am correct ?
Reply to R1+r2 test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hope you get better soon .sounds quite serious
Often, but not always: 543.2.9 Except where the circuit protective conductor is formed by a metal covering or enclosure containing all of the...
