Radials V Ring mains | on ElectriciansForums
Discuss Radials V Ring mains in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
London
Hi all,
This may be a common topic and may already have been spoken about 100s of times so forgive me in advance.
I have always wired in ring mains for my sockets up until recently..
I came across an install where all sockets were wired in 2.5 radials protected by 20A RCBO they had wired 3 bedrooms all on separate 2.5 radials (Loft & 1st floor)
i did question why each room was separate and the response i got was "customers request due to computers"
I am hearing more and more people wiring 4mm radials protected by 32A as its "convenient"
whats peoples general thoughts on this?
Each room is on a separate radial with around 4 sockets in - very weird arrangement i know
Hi all,
Great idea.
20A is plenty for a bedroom and when the kids don't get off the consoles you can switch off the mains to their bedroom.
Each type of circuit has its merits, whatever suits the need of the installation and the client.
Take it you do 4mm Radials?
Not any more Sparky 10, as I have been retired for a few years, but to answer your question, yes I did, but always in conjunction with the restraints and the advice in Appendix 15 BS7671, floor area etc.
I also ran 6mm radials whilst working in Canada @110Volts using MK 110V socket outlets, had nil trouble with connecting them up either. Just saying.
Just to be a Pedant they are not Ring Mains any more they are Ring Final Circuits or RFCs
I cannot understand how someone can be working on electrics in Canada and not know the voltage is 120v plus or minus 5%. 110v is a myth and outside the permitted tolerance.
Hi check regulations , can use radial 2.5 mm serves 50 square meters 20 amp cb& 4mm at 75 square meters 32 amp cb
If you think about it, if you take an RFC wired in 2.5 and supplied by a 32A MCB and: remove one section of cable, and split the tails across two 20 or 25A MCBs then you have :
  • Increased the total available current from 32A to 40 or 50A
  • Reduced the amount of cable used
So the two radials (assuming a new install or a rewire) will need less cable and provide a higher total load capacity than the same outlets wired as an RFC. You've also (assuming RCBOs) reduced the amount of stuff that goes off when a breaker trips.
However, you've also increased the volt drops. So if the alternative RFC was on (or near) the limits, the two radials would most likely be over the limits for volt drops.
Reply to Radials V Ring mains in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
https://www.amazon.co.uk/gp/product/B08CJ3VC79/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 I use this, current clamps go round each outgoing...
If it's going to be an emergency stop and not just a stop, then other factors come into play depending on what sort of machines the emergency stop...
Why aren't you asking them?
As long as you can carry out all the necessary testing, certification, are insured to do the work and all is carried out to Amendment 2 of the regs
