Rangemaster Cooker Hood
Strima
i usually fit a FCU top of the wall cupboard and chase in to inside the flue. then a connector or wagos to the flex.
they not has bad putting them up most manufactures comes with a wall plan .
No I agree Buzz not that bad really but I had one where there was a low ceiling and to get the minimum height from the hob just one of the 2 chimney sections was too long, so that had to be cut down with a jigsaw with metal blade, then it had to be jiggled into place with the main hood loose as no adjustment and this particular one was about 1200mm wide.
Strima,
Dave OCD,
