but then you will get the job to correct the cowboy
I have used SY in the past in place of flexible cables , because dogs kept chewing flexes ...
Have used steel security tubing on squirrel infested nursing homes, it thinner than gav conduit. Couplers, bends etc, are clamped on using tension screws. Quick & easy fitting available 8mm, 10mm, 12mm....... to 25mm
slip tube might work well as well if you cant get the security tube.Where do you get it from? I've tried to get hold of it before for running cat5 in but had no luck
small tube we get from Enterprise Security, lager tube, Wilson electrical up you way ordered it for us
http://www.enterprisesecuritydistribution.com/intruder/tube-and-trunking
no a new A+E in wolverhampton is being done in itI thought that stuff disappeared years ago?
Very trueBecause if the cost is higher than they're willing to pay/can afford you'll probably lose the job to a cowboy.
Did a school classroom in SWA because the cables kept getting chewed by squirrels , call to a hotel fire yesterday where a rat had chewed through a switch wire , the wire had got wet , and due to not having an RCD arched smoldered and set fire to the floor boards cables now installed in that area in connex
